Posted by wfd2 on August 25, 2009 at 19:27:38 from (68.245.141.25):
Hello,
About a month ago I purchased my first Farmall H. I knew that the generator and the VR was disconnected, but it had a new 6v battery and started and ran well. The new battery is a Napa 6v commercial battery that turned over the tractor very well before. The tractor is equipped with a distributor.
Rewiring the 6v system is on my to-do list (Using the troubleshooting and wiring charts from this forum, THANKS!), but I figured I had time to do this if I charged the battery (float charger, 2A, automatic) between starts.
I used it last to cut a field, about an hour of use. That day it seemed to get harder to start, as if the battery was getting weak. I then parked it for about a week (without charging, float charger said "charged" battery) and went to start it again. This time the starter turned over very slowly and then just stopped. I checked battery with voltmeter-- read 5.4v, so I hooked up a 6v charger to it and went on my way.
Now, battery reads 5.9v but starter still will not turn over (might get a click out of it).
I know I have to correct the wiring problem (actually, VR and Gen don't even have wires connected) but shouldn't the tractor run OK with me charging the battery after using the tractor? Or does this sound like a deeper problem, like a bad starter or defective battery?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
