In the early fifties, I changed or helped change wheels on an M Farmall. We used a railroad jack,a ten ton screw jack commonly available in that time frame,to lift the tractor. We used a chainfall, a block with two sized chain pulleys with a mechanical advantage of about 20 and a capacity of a ton. With a section of Richards-Wilcox hay track and trolley strapped to one of the barn beams, the wheels were lifted up and over the tractor, turned and installed on the opposite side. Barn loft beams in those days would carry the load easily. I suspect the wheels weighed between 800 and 1000 pounds.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
