Serial # L 504802 and higher came with 3 bolt. Original starter used a switch with lever on top operated by a pull rod. If you have a actual solenoid mounted on top with 2 bolts and a metal strap to post, it and starter are probably from a 300 to 450 tractor or some others and could be 6 or 12 volts. Sometimes it will say on the solenoid, or have a number that could be checked. Saw tractors converted to 12 with 6 volt solenoids that worked for a long time so don't know how much difference it makes. Most 12 volt have a small extra terminal on them to send full voltage to the coil when cranking.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
