Re: F-20 flywheel installation
Posted by spiffy1 on August 26, 2009 at 09:10:58 from (70.41.135.42):
In Reply to: F-20 flywheel installation posted by GordoSD on August 24, 2009 at 09:25:00:
I'm a fan of heat, but on the 22-36 I put together last spring, it was so cumbersome, I knew that alone wouldn't be an option:
Pretty sure the F-20 cranks have the internal threads as well, but since I haven't tried this on anything else may have to eat my words.....
Anyway, pull out the pilot bearing oiler (good excuse to replace the pilot bearing too!) and screw in a some ready rod [actually, I cut the end off a bolt and made an adaptor for my sleeve puller as that 22-36 has a pretty big thread compared to what I have laying around in ready rod] and you're good too go.
