Re: 47 Farmall H correct gear oil
Posted by randy hall on August 26, 2009 at 15:09:51 from (209.143.0.64):
In Reply to: 47 Farmall H correct gear oil posted by wfd2 on August 26, 2009 at 10:34:56:
unless you are in a very cold climate and you will use your h a lot when it is cold use 140 weight. it won't leak out near as easy. everything in your h transmission has sixty years of wear. the heavier oil won't hurt a thing. most of them have oil that is as thick as tar in them.
