Re: 47 Farmall H correct gear oil
Posted by wfd2 on August 26, 2009 at 18:03:14 from (173.124.233.49):
In Reply to: Re: 47 Farmall H correct gear oil posted by amnion on August 26, 2009 at 14:09:29:
You"re right, the hydraulic pump does have some leaking going on. The pump isn"t hooked up properly, but that"s an issue for another post!
