Re: weight of a 1939 farmall M
Posted by railhead on August 27, 2009 at 06:26:59 from (71.143.182.14):
In Reply to: weight of a 1939 farmall M posted by tractornutjd on August 27, 2009 at 03:35:30:
your truck should be adequate to pull it at a reasonable speed and reasonable distance but I would worry more about getting a trailer that can handle the tractor width wise. The wheels on a M can be set pretty far apart. Rears dished out and in as far as they will go is still close to 8 feet wide depending on tire size. I have had to turn one wheel around too many times...once is enough.. to get one to fit on a trailer. A 8 wide trailer with no side rails is best.
