Re: Adjusting Wide-Front end on Farmall M
Posted by Andrew Z on August 27, 2009 at 20:21:35 from (64.148.20.45):
In Reply to: Adjusting Wide-Front end on Farmall M posted by Stevie J. Mote on August 27, 2009 at 19:10:10:
most likely its going to be really frozen... so what we do is spray the heck out of it with pb blaster or the like. after put a 8 to 12 ton jack on the top of the axel with a pice of channel iron as a spacer between the sides. once you get both sides off clean them up really well dont forget the inside of the tube, then never-sieze the pices and move them in. thats the only way we have been able to get them to move in is by going out first.
Andrew
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
