Posted by dhermesc on August 28, 2009 at 05:48:43 from (24.248.193.103):
In Reply to: 560 wide front axle posted by CGtractor on August 27, 2009 at 16:56:08:
That doesn't surprise me, I snapped the hub and axle off the Swartz wide front on my 350. The factory weld only had penetration on about 1/3 of the weld. The fact it had held for 30 years was probably due to the light use the tractor had enjoyed - putting a loader on the front has added quite a bit of stress.
After I ground the weld off I took the spindle and hub to a welding shop to have it done right. I would suspect you could do the same with yours. I was tempted to try it myself but the thought of losing the front hub again while in road gear made me decide on using a guy that trained in welding.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
