Posted by RustyFarmall on August 28, 2009 at 06:40:34 from (209.152.78.140):
In Reply to: 560 wide front axle posted by CGtractor on August 27, 2009 at 16:56:08:
During that era there were probably 4 different makers of wide fronts. Of course IH made one, and then there was Norden, Speeco, and Schwartz. Norden is gone from the picture completely and replacement parts are very hard to find. Schwartz and Speeco are now the same company and still producing parts as well as complete assemblies, and of course IH parts are readily available also.
One way to identify between a Schwartz or Speeco is to look at the tie rods. The Speeco tie rods have holes. The Schwartz has notches.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
