Re: '48 H ignition switch location
Posted by Janicholson on August 28, 2009 at 07:58:41 from (199.17.6.222):
In Reply to: Re: '48 H ignition switch location posted by chad504 on August 28, 2009 at 07:41:43:
I have seen them on the lower bracket, and on the light bar, so sense it is not a stock system anyway, do it as seems easiest to use. JimN
