Re: wheel weights and sledge hammers
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Paul Shuler on April 18, 2000 at 16:08:26 from (205.188.197.173):
In Reply to: wheel weights and sledge hammers posted by alan on April 18, 2000 at 14:28:47:
This is how I got mine off after being on there 47 years.Sprayed lots of oil on them and after much labor got all the nuts off.I took a bolt of the same size and got on the inside of the wheel and placed the bolt with the head faceing out against the bolt going through the weight and wheel and with solid tapping from a claw hammer drove them right out. It screws up the threads a little but I would use new bolts anyway. Oh by the way when you drive out the last one you make sure that your foot,small childern or lap dogs that you want to save are out of the weights path cause when it comes loose its going where it darn well pleases.
Post A Followup
: Re: Re: wheel weights and sledge hammers
