Re: '48 H ignition switch location
Posted by RustyFarmall on August 28, 2009 at 08:10:24 from (209.152.78.140):
In Reply to: Re: '48 H ignition switch location posted by Janicholson on August 28, 2009 at 07:31:48:
I've got a '50 H in original condition. It has the ignition switch mounted in the same bracket that is used to mount the belt pulley lever and the radiator shutter control. I don't think the ignition switch in the amp box was done until the Super H was introduced.
For what it's worth, my 1940 H has the ignition switch in the same approximate location as the '50.
