Re: Farmall H 2-way valve for hydros
Posted by RustyFarmall on August 28, 2009 at 08:15:38 from (209.152.78.140):
In Reply to: Re: Farmall H 2-way valve for hydros posted by ryanwheelock on August 28, 2009 at 07:52:44:
No, I cannot get those. That style is no longer available new. It will have to be found in a salvage yard.
I CAN fix you up with a brand new valve that will do the same thing and probably for less money. The new valve can be mounted in any location that is convenient for you, and then run a return hose to the filler neck.
