Re: Variation on the H oil--question
Posted by Theman on August 28, 2009 at 10:10:23 from (63.107.135.35):
In Reply to: Re: Variation on the H oil--question posted by wilkens on August 27, 2009 at 19:33:17:
I believe the drain plug Randy is referring to is the front transmission drain plug. It isn't on the belt pulley housing itself. When changing the oil, the manual recommends adding some fresh oil to the pulley gearbox. Put the first quart in the belt pulley housing, then pour the rest of the 6 gallons in the large hole in the top of the transmission cover near the shift lever. The level check plug is on the left side of the transmission case (viewed while sitting in the seat) ahead of the clutch pedal pivot shaft.
