Re: IH-H carb
Posted by CJ_1080 on August 29, 2009 at 15:15:05 from (166.233.67.150):
In Reply to: IH-H carb posted by bigsal on August 29, 2009 at 11:30:33:
You aren't getting enough fuel. When you rebuilt the carb did you tripple check the float height? Try taking the fuel line off the carb and draining some fuel into a CLEAN can or bucket. The fuel should flow quickly and steadily. If both of these are ok than just tune the carb as previously stated. Good luck
