Re: Farmall A help
Posted by El Toro on August 29, 2009 at 16:45:39 from (64.12.116.73):
In Reply to: Farmall A help posted by 7lazy77 on August 29, 2009 at 15:58:42:
Clean all battery connections until shiny and that includes the surface where the battery is grounded. Then make sure they're tight. Any rust or paint where the battery is grounded are very good insulators. Then see if the engine
crank over with the starter & start. Hal
