Re: poor circulation on H
Posted by Jeff Z. on August 29, 2009 at 20:56:23 from (74.76.3.113):
In Reply to: poor circulation on H posted by maestro on August 29, 2009 at 20:27:58:
First make sure the bottom radiator hose isn't collapsing when hot.
Make sure fan belt is tight enough.
Get a new water pump.{Can't hurt}
A good test for a bad radiator is to plug the bottom hole and fill with water. Remove the bottom plug and the radiator should empty with one big gush of water with some force behind it.
If the water comes out slow or in spirts the core is plugged.
