Re: super c hydraulic oil in crankcase
Posted by gene bender on August 30, 2009 at 06:01:25 from (67.55.227.88):
In Reply to: super c hydraulic oil in crankcase posted by carl Schreiner on August 30, 2009 at 05:16:44:
You need to pull the pump to see what seal is used some had a seal and some had an o-ring. Check the shaft as it mite be worn down where the seal goes and then you will need a speedy sleeve over that spot so the new seal can do its job. yOU can take it to any parts place and they can get the parts you need.
