Re: super c hydraulic oil in crankcase
Posted by archie3crunet.com on August 30, 2009 at 06:06:20 from (74.254.138.125):
In Reply to: super c hydraulic oil in crankcase posted by carl Schreiner on August 30, 2009 at 05:16:44:
My C done the same thing. there is a o-ring in the small hydraulic pump on the right side of the tractor. There is a shaft that can be brazed up and cut back down to spec. This will fix your problem. I done mine about a year ago and have not had any problems since.
