Re: IH-H carb
Posted by rustyfarmall on August 30, 2009 at 06:23:54 from (209.152.78.140):
In Reply to: IH-H carb posted by TomH in PA on August 29, 2009 at 15:57:57:
TomH in PA said: (quoted from post at 15:57:57 08/29/09) I'm pretty sure the screw on the bottom makes the mixture richer as you screw it in.
No, screwing it in makes it leaner. If you screw it in until it stops, there will be NO fuel flow.
