You are probably right about the axles if they were military surplus. Since elwood was already furnishing the drop boxes it would be no trouble to change sprockets if there is room. Those type military axles were before my time, at least were I was in the military, worked on them from 69 to 71, the 2.5 and 5 ton used the drive shaft through the top type. Thinking another reason fourth wasn't used is the 4th sliding gear could see a lot of wear if a lot of work was done in 4th. Gear driving it from bottom and it driving another gear. Think there would be a lot of side load on the main shaft piliot bearing to the right side general area of tractor also in 4 wheel 4th. Just thinking out loud, can't say for sure.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
