Posted by Bill47 Perry on August 30, 2009 at 09:52:34 from (64.12.116.73):
My H has a parial misfire after about 2 hours of running with a finishing mower behind it. Ignition is an IH magneto. What plug wire type, Copper conductor or other should be on it. It has Belden r3 marked on the wires. Is the coil in the magneto the most likely cause? Could it be carburetor float due to some gas being burned since starting with a 3/4 full tank? This problem is repeatable but seems to be getting worse. It started when backing up to turn around. With the throttle just above idle it would sputter and then pick up the load backing up. It then would sputter when going back to full load with the finishing mower and then smooth out. Any help would be appreciated.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
