Re: super c hydraulic oil in crankcase
Posted by El Toro on August 30, 2009 at 10:12:34 from (205.188.116.73):
In Reply to: super c hydraulic oil in crankcase posted by carl Schreiner on August 30, 2009 at 05:16:44:
third party image
Here's a parts breakdown on the pump. The old seal may have worn a groove and you may need a speedi-sleeve. Napa has them to cover that area.
Hal
