Posted by gene bender on August 30, 2009 at 12:44:19 from (67.55.227.88):
In Reply to: 200 FARMALL posted by WHITE GOLD on August 30, 2009 at 12:19:30:
Check around but dont you just slide the axles out then remove and replace the diff gearsa half turn so it drives the axles the forward way someone will answer that used to do it every yr for other farm use.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
