Re: 460 to 560 diesel
Posted by Harold H on August 30, 2009 at 13:28:39 from (98.18.183.82):
In Reply to: 460 to 560 diesel posted by milo7890 on August 30, 2009 at 11:42:14:
It should work, will give you a longer stroke which will probably give you about 240 cubic inches. Check the bolt pattern on the flywheel flange to be sure it is the same. The front pulley will probably be different but should work.
Harold H
