Posted by Harold H on August 30, 2009 at 13:37:32 from (98.18.183.82):
In Reply to: 200 FARMALL posted by WHITE GOLD on August 30, 2009 at 12:19:30:
We never sold pickers on the C thru 240 tractors, but, it should be the same as the M and H sized tractors. Remove the transmission top and move the shift lever to the other side and install regular shift rails, those in your tractor are reversed rails. Pull the axles out far enough to flip the differential cage and reassemble everything. Turn your rear wheels so the tread will run forward and be sure to turn the front wheel so the caster will be trailing so it will steer right.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
