Re: Mike's Radiator Grill fit
Posted by Owen Aaland on August 30, 2009 at 16:44:43 from (65.174.247.87):
In Reply to: Mike's Radiator Grill fit posted by GordoSD on August 30, 2009 at 07:56:23:
Your radiator should be mounted so that the steering shaft in in the center of the hole through the radiator. You need to have some pad thickness under the radiator so that vibration does not cause wear on the bottom tank. On pressure style radiators you can adjust the position of the top of the radiator to get the best fit front to back. If your steering shaft only hits on the back you probable need to adjust the top rod to make it shorter. If you go too far either way the grill will not fit correctly.
