Re: 39 Farmall Rearend
Posted by Owen Aaland on August 30, 2009 at 16:50:07 from (65.174.247.87):
In Reply to: 39 Farmall Rearend posted by J wilbur on August 30, 2009 at 06:05:59:
cory smith said: (quoted from post at 17:48:17 08/30/09) Thanks a bunch what about the gear that closest to the bell housing it it pretty big I think its first and reverse. Thanks a ton its a big relief that I don't have to find another 39
Transmission speeds are from the engine back: 5 is direct coupled to the input shaft, then 4,3,2,1,R. Reverse gear works of the idler gears in the back.
