Posted by D Slater on August 30, 2009 at 18:10:14 from (72.65.136.11):
In Reply to: Re: 39 Farmall Rearend posted by cory smith on August 30, 2009 at 14:48:17:
Gear closest to front on the top shaft is the belt pulley gear box drive and its part of the transmission input shaft. next one back is the constant mesh drive gear also part of the input shaft, next is 4&5 sliding gear, next is 2&3 sliding gear, next back 1& reverse sliding gear. On the bottom shaft starting at the front. Constant mesh gear, then 4,3,2 and 1 gears that drive the ones on top shaft. Hope we were on the same gear in the other post the 2&3 sliding gear. They are called sliding gears because they slide back and forth on shaft when shifting. I may have a good gear, can look tomorrow if interested.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
