Re: TIRES AND WHEELS FOR M FARMALL 18.4 x 30 ?
Posted by RustyFarmall on August 31, 2009 at 06:58:32 from (209.152.78.140):
In Reply to: TIRES AND WHEELS FOR M FARMALL 18.4 x 30 ? posted by Walter in Ky on August 30, 2009 at 18:47:56:
Probably the easiest way to accomplish that goal would be to locate a pair cast centers from a 400 or 450. Those centers will accomodate the double bevel rims, and then you can find some rims that are wide enough to mount the 18.4 tires. I know of one M that has been altered in this fashion, and it does look impressive. A word of caution though. An M is not heavy enough to need that much tire, and while traction in soft ground may improve, I think the traction on harder ground would leave quite a bit to be desired.
