Re: 710 IH auto reset plow
Posted by 450D on August 31, 2009 at 09:16:46 from (74.85.197.86):
In Reply to: 710 IH auto reset plow posted by Randall W. Mertz on August 30, 2009 at 18:54:13:
Had the same problem, IH spring resets use only spring pressure to hold bottom from tripping.Also used to break a lot of moldboards because of resetting on top of the rock that tripped it. Traded for a Melroe 903 6-18"s auto reset trailer plow. A LOT more clearance = less pluging and they have a overcenter linkage so they don't backout of the ground in tough plowing.
Problem solved could'nt be happier.
Dave
