Re: Woodruff key repair in P.S. shaft
Posted by HENRY E NC on August 31, 2009 at 15:29:27 from (67.142.163.25):
In Reply to: Re: Woodruff key repair in P.S. shaft posted by Mike Farmer on August 31, 2009 at 03:56:06:
I am a fan of JB Weld but there are better products for your application. The epuxy sticks are much better in thAT application. I would probably fill in the key way with braze and then cut it out with a rotary tool ( dremel etc.) Leaving one side original would be a benefit. The best repair would be to fill it and and have a new keyway cut at a machine shop in the shaft Henry
