Posted by Darryl Sparlin on August 31, 2009 at 15:38:20 from (173.20.36.242):
In Reply to: IH-H carb posted by bigsal on August 29, 2009 at 11:30:33:
This sounds exactly like the problem I was having with my 46H. I found that the manifold was leaking. The bolts were just snug. I put on new gaskets and torqued them at 28-30lbs and it runs very well. Also check and make sure the governor is seated in the notch where it ties into the carberator. Mine was out of the notch. Also make sure bolts are tight on top cover. I had some that were very loose.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
