Posted by Hugh MacKay on August 31, 2009 at 16:36:18 from (216.208.58.183):
In Reply to: 2 point? posted by kendal on August 31, 2009 at 16:05:44:
Kendal: It is manual draft control, designed primarily for setting plow depth, or changing depth on the go. It also adjusts any ground working implement so front cuts same depth as back of implement. Disk is a prime example, you adjust that control so back and front gangs cut the same. When you using this the lift cylinder should be in single action setting, then implement floats at your desired depth. Well designed for that era.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
