Re: Gasket Farmall C Hydraulic Pump
Posted by Johnny D on August 31, 2009 at 19:06:03 from (97.95.145.71):
In Reply to: Re: Gasket Farmall C Hydraulic Pump posted by CNKS on August 31, 2009 at 18:22:25:
what about on the gear side of the pump where it mounts to the tractor with the two corner bolts?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
