Re: 340 U
Posted by CNKS on September 01, 2009 at 18:35:20 from (216.144.104.128):
In Reply to: 340 U posted by Moondoggie on September 01, 2009 at 18:16:00:
You don't need to bleed the oil line. Pressure may be slow to get to the gauge, but it will come up. I don't know about the 340, but on my 460 which has the same basic hyd system, I just put a bucket under the cylinder. My cylinder has been off a couple of times without a stream of oil coming out. This is with the Tel-A-Depth system. I am not speaking for the rest of Hydra Touch. If any question on any cylinder, I slowly loosen the hose, making sure I am out of the way. I have seen a pretty good stream of oil in certain cases. Sometimes moving the levers with the engine off relieves the pressure, mostly not. Just be careful.
