Re: Farmall A backfire
Posted by Janicholson on September 01, 2009 at 18:42:41 from (64.61.211.37):
In Reply to: Farmall A backfire posted by Bryan Monaco on September 01, 2009 at 13:57:10:
The mag must click (the impulse coupling) when it passes the timing mark.
Set the engine pointer just before TDC on the F/W 1/2" or so, but moving it in the correct direction only, and not going past.
Loosen the mag in its slots and turn it till it is retarded (CW) as far as it will go. Then set the engine at TDC going forward only. Then turn the mag slowly CCW until it clicks. lock it down. This cocks the mag impulse, then times the release to TDC. When running, it is advanced to the correct position. When starting it must be at Impulse TDC. JimN
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
