Re: super C Crank pulley- What now
Posted by Janicholson on September 01, 2009 at 19:09:25 from (64.61.211.37):
In Reply to: super C Crank pulley- What now posted by Mark-Mo on September 01, 2009 at 18:43:05:
Use a pin punch (or oil quenched pole barn nail) to break up the drill bit. It will take some effort, but should splinter with some angular hits.
Another possibility is to use a small cold chisel to spin the rod out by chiseling CCW on the perimeter of the broken end. If the rod snapped from tightening a nut on the pushing plate, or collar, it might not be tight in the threads at all.
Welding a nut on the end of the rod (through the hole in the nut to the shaft of the ready rod) will also work. Use a bolt one size smaller than the ready rod (9/16" nut on a 5/8 ready rod) let it cool to shrink, and turn out with socket.
When it is off, polish out the inside of the pulley until it goes on by firm hand pressure at least 1/3 of the way. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
