Posted by Janicholson on September 01, 2009 at 19:15:59 from (64.61.211.37):
In Reply to: Farmall Cub posted by FarmallZach on September 01, 2009 at 18:54:04:
The under side (crank) is not frozen. Unles it was living in water, then there is no recovery except complete rebuild. Pulling the plugs and putting a half cup of auto trans fluid in each hole, then waiting for several days can be wonderful. Bumping the starter with a good battery will break it loose. Do not hold it on start, just repeated bumping for 14 second, repeated 5 to 8 times, then walk away. Watch the fan. if it begins to turn, do not continue to turn it. Remove the plugs and then try it. (oil does not compress, and needs to be free to leave through the Spark plug holes.) Good luck. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
