Re: super C Crank pulley- What now
Posted by ScottyHOMEy on September 01, 2009 at 19:33:57 from (71.241.217.214):
In Reply to: super C Crank pulley- What now posted by Mark-Mo on September 01, 2009 at 18:43:05:
You've got a bit of a mess but don't lose your head. It happens. And there is a way out.
A few questions. How much of the drill bit is in there? Is it broken off flush with the face of the broken off allthread or sticking out? Same thing with the allthread. How much if any of it is sticking out the front of the crank? How far on is the pulley? Can you get it back off?
I'm the sort of guy who's cleaned up enough cobbled-up messes that my conscience won't let me leave a mess for the next guy. If the pulley is all the way on, you could leave it as is and run it, but that allthread is only gonna become harder to get out over time.
Getting it out will likely mean pulling the pulley back off for starters. If it isn't all the way on, a little fast heat from a Mapp torch should loosen it up enough to get it off.
From there a lot depends on the answers to the kinds of questions I posed. It could be as easy as a larger carbide (i.e., HARD) bit to drill out the stub of the drill bit that's in there, and then using a left-twist drill to get the allthread out. Worst case would be having to weld a nut over the allthread, snapped-off bit and all, to get the whole mess out at once. Welding on a crank is always touchy and at the lest will mean a new seal for the timing cover, perhaps more. But there's a lot of options/possibilities in between.
Bottom line . . . it's all fixable, but more details will generate more good ideas to get you out of your fix.
Let us know.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
