Posted by El Toro on September 02, 2009 at 04:07:00 from (64.12.116.73):
In Reply to: t-9 ih crawler no spark posted by jeffrey brown on September 02, 2009 at 02:32:59:
Does it have a mag or a distributor? I would clean the points with some 320 wet or dry until shiny. If you have a distributor you need battery voltage. With the points open & the ignition on you should have battery voltage on both small terminals on the coil. If it has a mag you should hear the impulse coupling snap. Hal
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
