Re: Another Project - H Engine Stuck
Posted by rustyfarmall on September 02, 2009 at 08:07:17 from (209.152.78.140):
In Reply to: Another Project - H Engine Stuck posted by Clarkbug on September 01, 2009 at 19:09:53:
If it is as simple as that one cylinder being rusted, then the ATF will eventually do the trick but you'll need to rock the engine a bit as well.
If the anti-freeze was too weak, and actually froze in the water jacket, then you've got major serious problems 'cause you probably are dealing with busted cylinder walls, and while that CAN be fixed, it would be easier to just find another engine or at least a different block.
