Re: farmall 300 spewing rad fluid
Posted by SDE on September 02, 2009 at 18:48:51 from (174.124.35.151):
In Reply to: farmall 300 spewing rad fluid posted by bscary on September 02, 2009 at 17:32:46:
If Too Far Gone is correct, you should retorque the head bolts. It may solve your problem, If you are lucky.
SDE
