Re: 1066 TA questions
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by SDman on April 18, 2000 at 22:22:19 from (63.83.208.200):
In Reply to: 1066 TA questions posted by T16 on April 18, 2000 at 20:24:34:
This sounds like a classic example of a worn out MCV(power steering) hydraulic pump. If the TA downshifts when brakes are activated, that pump is not supplying enough oil to keep the TA engaged & supply the brakes as well. What is happening is that your TA is losing oil pressure & the mechanical sprag clutch on the low(TA) side is what is driving the tractor when brakes are applied. When the brakes are released there is enough oil to satisfy the TA assy. This is also indicated by your road gear description. Also when the oil heats up, the more a weak MCV pump will show up. Does the Lo transmission pressure light work?(Should be on the RH panel by the key switch, it should come on everytime you step on the clutch). If so, I would imagine it would be on about all the time. Get the pump tested & more than likely replaced before you tear up your TA & then you will have big$$$ in repairs. Hope this helps.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
