Re: Do I have 3 hydrolic outlets on my M
Posted by rustyfarmall on September 03, 2009 at 07:25:32 from (209.152.78.140):
In Reply to: Do I have 3 hydrolic outlets on my M posted by KC Bob on September 03, 2009 at 06:59:13:
The 3 outlets are all connected at the pump, so basically you have just one outlet, and it is for use with one way, lift only hydraulic cylinders. If you want to use it with 2 way cylinders, you need to add some equipment to the tractor.
