Re: Super C Clutch Adjustment
Posted by ScottyHOMEy on September 03, 2009 at 12:19:17 from (71.241.196.238):
In Reply to: Re: Super C Clutch Adjustment posted by Andy Martin on September 03, 2009 at 12:14:14:
Some do, some don't, but that's a good idea/thing to check out! They would hold the plate back, so that Kevin wouldn't be feeling any pressure over most of the throw of the pedal other than the return spring on the clutch pedal. The fingers would be floating and could be far enough ahead that his bearing can't reach them. It would also keep him from moving.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
