I have welded nuts on to broken bolts. Sometimes the heat from the welding will break the broken bolt loose for you and they will turn out easily.
Or try to drill them out. Measure how deep the hole is in the jacket and make sure that you do not drill through it. Sometimes I will use a 1/4 by 20 tap to thread a bolt in to a broken 5/16 bolt. Apply heat to it after you have drilled it out. Maybe the thin wall of the broken bolt will absorb enough heat to come loose. Use a penetrating oil after you have heated it and hope it sucks in some. Just be careful to keep the drill centered on the broken bolt the best that you can. Steve
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
