Re: Can you run a log splitter off of the M
Posted by mattofvinings on September 03, 2009 at 16:27:24 from (67.142.161.35):
In Reply to: Can you run a log splitter off of the M posted by KC Bob on September 03, 2009 at 14:42:39:
Using the GPM or cu-in/rev rating of the hydraulic pump and the bore and stroke of the cylinder one can come up with a very educated guess about the cycle time.
In other words, the pump only positively displaces so much fluid per revolution of the input shaft. The hydraulic cylinder has a known volume in cubic inches that need to be filled to make a full stroke. How fast the hydraulic pump shaft is running makes a difference.
The pump peak pressure and the cylinder bore are used to determine peak force that the hyd cylinder can generate.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
