Re: can an 806 pull a 6-16 plow
Posted by MeanGene1 on September 03, 2009 at 20:13:53 from (204.14.185.168):
In Reply to: can an 806 pull a 6-16 plow posted by Andy W. on August 30, 2009 at 17:23:14:
We kept the first "demonstrator" 706D that came through my grandfather's dealership, it worked the shows and plowing demonstrations with 5-16's, the "steerable" plow, and we added another 706D the next year. We had that 5-16 for one year, and Gramps swapped it for a 4-16 that the 706 would pull full depth in L4 at 1800 and just sniff at the fuel tank, and did a beautiful job, furrows would lay out flat. Our neighbor bought the demonstrator 806D and 6-16 plow, was still using it that way the last time I saw it in the late 70's when he passed away. He had an old 560D that came behind it with the 16' spring-tooth drag, and then the 806 went on the big 4-row potato planter- everybody had told him that binder would never pull that big planter, and they were all pulling theirs slowly with weighted D4 Cats- the old 806 pulled it in L3 at 3/4 throttle, cruising- the poor guy riding and watching over the planter feed was the speed control, not the power of the tractor. Then came the skinny tires and 4-row cultivator with hillers- he didn't like to run any other tractor. Ran two diggers, one on the 806, one on the 560, until he got a potato harvester- 806 again. Potato harvester required a stone picker- 806. Only time that thing didn't work every day was when it was snowing- and it was never in the dealership for a repair, not once, and he never had to go through the engine
